Imagery in MSR now is not clear.
<img src="/styles/default/custom/flags/id.png" alt="Indonesia" /> Indonesia
VIA 280
Hi All,
Why imagery in MSR now is not clear. Though the initial release was very clear.
Best Regards,
Adi
Welcome to TomTomForums Adi.
Over a year ago the MSR site had been revamped, making it easier to attach textual and pictorial information to a post.
Could you explain what you do not like, possibly with a screen print.
That looks very bad indeed.
On the other hand, with that white superimposed route it does not look like a MSR screen print to me, but I may be wrong.
Googling I am getting these coordinates which look completely different from your picture.
-5.86999, 105.75258
I just entered those Google coordinates into my MSR and with the satellite view I get the same as you!
Click on the view symbol at the right hand bottom to get a straight map view. You can then enlarge it and click on the map to make your changes.
There is no assurance the updated imagery for any particular location will be at a higher resolution, and in rare instances, may be lower!
Google Earth
has a 'history' slider that allows viewing prior imagery for the same location. Have a look with that.
Hi All,
Imagery getting better now
Satellite Imagery 0
Satelite Imagery gone 5
Satellite Imagery 2
Satellite Imagery 2
Satellite Imagery 5
Satellite Imagery 3
tomtom2024
