canderson
Moderator
- Joined
- Dec 28, 2007
- Messages
- 13,072
- Location
- Colorado, USA
- TomTom Model(s)
If you wish to reset all features and settings on your device, returning them to their factory defaults, or are asked to do so as a troubleshooting step for a device that is misbehaving, this video outlines the correct procedure:
How to reset your navigation device to 'factory defaults':
If the firmware on your device becomes corrupted, and your device is inoperable as a result (will not boot, or continually reboots) it is possible to force it to load a functional version, and then update to the current version if necessary. This video explains this procedure:
How to recover your device (Nav3 / Nav4)
How do I perform a factory reset on my device?
The steps on how to reset your device back to factory settings depend on the type of navigation device you have. Note : Resetting your device removes all your saved places and...
help.tomtom.com
