Help my make my screen more visible.
Conroe Texas
VIA 1605tm
Hi, new to TT & liking it, but I need help getting the display to look as close to my Garmin as possible. I have an XXL 540 & need to know which map scheme will provide the brightest & most contrasty display. I have downloaded a bunch of user provided schemes, but would like some input on which you have used & like. The ones that I have used seem a bit washed out in the day, even though my unit is shielded from direct sunlight. Any insight on this issue is appreciated.
Cheers,
kev
tomtom2024
