GPS Quick Fix
GO-910
Does anyone else have problems with the GPS Quick Fix? I just downloaded the recent one today and now my position on the map is all over the place. It seems like after an hour or so the unit seems to figure it out and correct it. I had the problem before and a subsequent GPS Quick Fix did fix the problem for a couple updates. Is there some data in there that is screwing up the unit?
Mechelle
