gps quick fix
Every time i log on to TT home it says theres a update for gps quick fix,is that normal?Ive downloaded it 4 times in 2 weeks.
The QuickFix updates frequency HAS changed.
TomTom changed the frequency that the QuickFix updates occur. In May '07 they updated about every 7 days. Now it seems new data is available daily. An update will be offered every time you log into Home.
I like the new updates.
If you don't want to download it just avoid it. Satellites do tend to move. We need to know where they are :D
updates
I agree 100 % pedro,but i just wanted to be sure i wasnt downloading the same file everytime,Thks for your input pedro
dupete
