I tried to use my Scala G4 headset with my GO500 but it would not connect.
It gives « incompatible device, the selected device does not support this service«
I can’t find a headset menue on the satnav, so I am trying to connect through the Network Services. This is probably why it won’t work as it could be looking for a Network.
I there a way I can use the G4 headset to listen to the voice commands?
Thanks.
Thanks.
