Go Camper Max volume adjust
Go Camper Max, Rider 500
I can't find a way of adjusting the volume on screen while in drive mode, is there a way?
Try tapping the screen and then you should see a volume slider at the next screen.
Tapping the screen just brings up the + and - for zoom
abowen
