GO 910 window suction mount perished
GO 910
My go 910 is working perfectly but the suction pad has perished and I cannot find any way of replacing this can anyone help
You can try putting the suction cup in water and boiling it for 5 min.
You can also try running the suction cup under water
Then it remains only to carefully dry the suction cup.
Thank you Unfortunately suction cup has broken up so need to replace it or mount but cannot find anything on Net
If the suction cup is broken it will be very difficult to find another one even on occasion.
That thing is more than 15 years old.
If the arm at the ball end is still OK you could cut off the suction end and try to attach it to a lever type like this.
abowen
