After installing recent GPS Fix and OS upgrade, my GO825 Live does/did the following:
- Started failing to to display live traffic updates
- No longer started up with car ignition- had to manually start it each time
- Then the battery failed to charge up- even after hours of charge, never got over 15% and now is virtually dead
- Now it wont even start unless attached to eg a laptop for power
- Even when started now under laptop power, it drum rolls, shows splash screen and then goes black with an audible static sound
- I have tried the full re-boot (hold start button 20 seconds etc but it wont get beyond a pictorial screen showing device not connected to PC (red cross indicated)
