I get this problem all the time, even when the device is connected to power in the car. Last week, by pressing the on-off button in some magic way, I got a status screen, but that showed battery at 84% charge, even though the device kept powering off. Tonight it won't stay working at all, even though the status shows 100%.
Do I disbelieve the status screen and change the battery anyway, or is there some other problem?
To get the screen, hold the on-off button down while it is turning on.
