Display Current Coordinates
GO Supreme
I have a GO Supreme. I can see no way to display current coordinates. Is this possible?
Great question. Yes, though you wouldn't expect to look there.
Do a search.
In the upper right, there's a button that allows you to define the search area ... select Whole map, Near Me, Town or city etc. The last entry there will be Latitude Longitude.
Touch that.
There will be examples shown there to show you how to enter coordinates for searching, using the most common three formats. The examples actually contain your CURRENT coordinates!
Thanks but I have no search option. That is where I am stuck. Am I not looking in the right place for Search?
It's the same way you search for any POI or address using the "Search / Drive to" button.
When you are on your search screen, look up in the upper right where you see on this particular pic the "Near destination". When you press up there on your search screen, you'll get a menu that looks like this.
What you cannot see is the last entry in the list, so hit the scroll down button (2) and you will see the next line (3) that allows you to enter latitude/longitude information.
You will find some of the details on page 86 of the manual for your device that describes various search methods. Again, when you get to where you could enter latitude/longitude data, the examples that the device shows for the three coordinate formats are all filled with your current coordinates. I'll try to get a screen shot of that screen when I get home later today.
Manual at https://tinyurl.com/wthyrmj9
I don't have that device so I cannot give you exact instructions but I believe you must be in 'step by step' mode which is selected in Settings. (Page 86)
Go to Menu | Settings | System and select Step by step search
Go to Menu | Drive To |Latitude Longitude
The second, third and fourth lines below the input cursor will show your current location in Decimal, DMS and GPS styles.
Добрый день. Я тож столкнулся с вероятной проблемой. У меня отсутствует вариант Широта/долгота. Не могу посмотреть координаты текущего положения. Пользуюсь Go Expert 7.
Have you followed the advice precisely of moderators Arno and canderson preceding your post? If so, what happens when you try?
Also, this is an English speaking forum, if you don't mind.
For the newest models like the Expert, it is also very simple. Please follow these directions!
Select "Search" in the main menu.
In the upper right corner, the default says "Whole map". Notice please that it has a down arrow, indicating other options are available!
Touch the "Whole map", and select "Latitude Longitude" instead of "Whole map"
When you do that, you get this display on the Expert. The three examples contain your current coordinates:
Да, я точно раскрываю совет модератора. На мой взгляд вообще нет вариантов Широта/Долгота. До недавнего времени этот пункт был там и я им пользовался. Я заметил, что в меню «Поиск» нет опций поиска мест по координатам. Спасибо за понимание.
Для новейших моделей, таких как Expert, это также очень просто. Пожалуйста, следуйте этим указаниям!
Выберите «Поиск» в главном меню.
В правом верхнем углу по умолчанию написано «Вся карта». Обратите внимание, что у него есть стрелка вниз, указывающая, что доступны другие варианты!
Коснитесь «Вся карта» и выберите «Широта и долгота» вместо «Вся карта».
Когда вы это сделаете, вы получите этот дисплей на эксперте. Три примера содержат ваши текущие координаты :
Вот как я это делаю. Я посылаю вам изображение меню, как оно у меня есть. Обратите внимание, что мне не хватает параметра Широта/Долгота.
@dlinny195
That is very strange. What version of firmware are you running on that device??? I took the screens you see above directly from an Expert 7" device!
Это то, о чем я говорю. У меня было так, как на ваших скринах. Теперь это как моя картина. Я посылаю вам изображение версии программного обеспечения.
Yes, very strange. Did you have access to the Latitude/Longitude option in a previous build of the Expert code???
Доступ был и на этой версии ПО. Совсем недавно я скачал карту России. Могло ли это повлиять?
Извините, но я давно работаю водителем грузовика. Этот TomTom у меня не первый. Я внимательно прочитал инструкцию и знаю, как пользоваться навигационной системой. Мне нужно знать, почему поиск широты/долготы на этом TomTom исчез.
Can the poster confirm he is using the step-by-step search???
Not an option / not applicable for the Discover/Expert series.
Working on it, but please be patient, пожалуйста. It may take some time to sort this out. It is an unusual situation that we have not seen reported before, and it is a weekend, so the people I wish to ask are not working now.
Since you say that this seems to have become a problem immediately after loading a map of Россия, have you experimented by deleting that map to see if the function of your device changes back to when it provided you with latitude/longitude options?
Remove the Russian map from TomTom Go Expert 7.Perform a soft reset.Plug in the Russian map.It works.
Работаю над этим, но, пожалуйста, будьте терпеливы, пожалуйста. Может потребоваться некоторое время, чтобы разобраться с этим. Это необычная ситуация, о которой мы раньше не сообщали, и сейчас выходные, поэтому люди, которых я хочу спросить, сейчас не работают.
Поскольку вы говорите, что это, кажется, стало проблемой сразу после загрузки карты России, экспериментировали ли вы, удаляя эту карту, чтобы увидеть, вернется ли функция вашего устройства к тому состоянию, когда оно предоставило вам параметры широты/долготы?
Я точно знаю, что вы имеете в виду. Я вернул устройство к заводским настройкам и перенастроил его. Это не дало положительного результата. К сожалению, я не могу сейчас снять карту России, чтобы проверить эту опцию (нет доступа к WiFi)
Montysa
