Case big enough for 1000 Go LIve and Cradle
Scotland
6200, GO Discover 7”, GO Exclusive
Hi Guys (UK)
I'm in search for a case big but compact enough for my new 1000 and it's cradle (which you can't fold down) :(
Was wondering if anyone had any luck finding one that fitted nicely? :thumb:
Hmmm... That would be quite an odd shape.
I reckon a small camera case would be your best bet - the mount might fit where the lens would normally go?
Personally I keep my TomToms in flat cases designed for Nintendo DSs or portable hard drives and the mount has to stay in the glove compartment or get carried in my hand!
31Den
