Cable advice
Classic
Mini usb connection in my new VW car,
can I buy a cable from the mini USB straight to my sat nav or do need a adapter.
I presume you want to connect it to provide the power to run it.
I asked a similar question with regards to my Alfa Romeo Giulietta
The answer is it depends on the power output from the USB socket as the PND has a relatively high demand which most USB sockets cannot match. If the socket isn't powerful enough then an adapter won't make any difference
I think I’ll to visit the VW dealer.
All I need to do do is leave the sat nav plugged in on a long journey but all I have is four mini usb ports and no cables.
germangholami
