Bluetooth connection supreme..stuck on "one moment please
Supreme
Hey all
I had some issues with accessing traffic updates, so I did a reset of my tomtom supreme..which worked
The problem I have now is to the Bluetooth connection
I go through the motions
Mydrive app ..scan code..
Then one moment please
It stays on this and processes no further. Spinning wheel
Tried uninstall of app
Tried another reset
Tried adding another device
Phone can see the device
App shows device not in range
Any thoughts
Pixel 6
It used to work
@raesewell thank you this
Tried
- uninstall app and reinstall
- uninstall device from phone
- reset tomtom (again)
It still gets stuck on "one moment please"
My phone can see the tomtom
Tried add a new device (phone) via app
Same issue
Hi
Have you tried connecting your phone using only Bluetooth
without using the Mydrive application.
Montysa
