Adjust speed warning?
<img src="/styles/default/custom/flags/no.png" alt="Norway" /> Norway
tomtom go premium x
I have a tomtom go premium x. Is it possible to adjust the warning for the speed limit? I would have it 5 or 10 km over the spedd limit...
Welcome to TomTomForums,
The difference between posted speed limit and audible alarm varies with actual speed
At 50 it may be 3 - 4 km/h. at 100 about 8 - 10.
Monitor your device to get a feel for it.
I disabled that sound a long time ago as it comes on ever time one goes over the threshold and used to drive my wife crazy.
It triggers off a fixed percentage of the 'posted' speed (as the map knows it, anyway). No mechanism to adjust it.
Try TomTom's own public English support group but I think the moderators there can only pass on requests through levels to the developers.
31Den
