What is the input power plug for a VIA1435TM
I'm trying to get a PC USB charge/sync cable for my VIA 1435TM.
Anyone knows the kind of input plug for the VIA 1435TM?
It's not a mini-USB plug. It's a flat kind of input plug (like my Samsung bluetooth headset's charger plug).
Is it a micro-USB plug?
Thx.
Yes, I do believe it's a micro usb plug but weren't you provided with a cable for your unit?
If it's like I'm thinking, It's a bit of an odd one, because of the integrated mount on those models.
The supplied charger *is* a mini-USB and that plugs into a mini-USB socket on the integrated windscreen mount.
The mount then has a short flying-lead terminating in a MICRO-USB plug that fits into a socket on the PND's body.
So you don't get a charger cable with a micro-USB plug on it , dhn ....
EDIT - Ignore me... different model entirely! The VIA 1435TM has an integrated mount, but it's PASSIVE!
So, fk91km... a micro-USB lead WILL work, but what's happened to the one that came with it?
