Tripmaster Audio Problems??
San Diego CA
I installed TripMaster 1.7a into my TT910 running 6.510 It seems to work as advertized however all audio seemed to be disabled from the TT910 navigator except for the overspeed alarms from Tripmaster. This didn't seem to depend upon whether tripmaster launched or not.
I removed tripmaster and audio seems to have returned.
Does anyone have an idea what is happening.
Bob
P.S. Is there a third party program that only logs position and time?
Bob
Never noticed such a thing on my GO910.
If you only want to log position and time, use NMEALogger.
Tripmaster Audio?
Thanks for the response Roussillat. I will look into the nema logger. The Audio may also be a problem with the Audio settings on TT. It also appears if the language is set to a foreign lanquage different from th North american map there may be "interesting" behavior.
Bob
