traffic reciever problem!
Hi everyone.
I have just bought a tomtom xl v9.
I want to buy a traffic reciever for it, but am so confused as to which one is compatible.
Can anybody clarify which one is compatible.
Plenty say they are compatible with ONE xl, but don't say which versions. Maybe they are compatible with all versions but who knows. My v9 is a mini usb connection so can I get any mini usb traffic reciever?
Please help....
You need the RDS-TMC unit that is equipped with a mini USB plug, the receivers with the round connector won't be of any use as there is no socket on the device for this to be inserted in to - Mike
thanks, do all versions of the one xl with mini usb port use the same rds tmc reciever? I was under the impression that there were different versions for different models.
AFAIK, there is only one current RDS-TMC receiver with a USB connection.
Why not just buy from the TomTom website?
