Totom start flashing red cross
TomTom Start
Device was working perfectly today then suddenly turned off/on and flashing red cross appeared thought at first it was just the heat. I have since tried backup from tomtom home.....no good then from saved back up on laptop.....no good still get red cross when turning back on, what else can I do
Your GO 820 doesn't use TomTom Home. It's a generation past that.
You need to load and run TomTom MyDrive Connect to work with an 820.
Here is an article from TomTom that may help you to deal with a system recovery for your device.
1EX00 is not a TomTom model number. There are a lot of models that have carried the "Start" name over the years, covering a couple of different generations. Can you supply the first two characters of your unit's serial number? That will nail it down clearly for us. I'm guessing it may be the older Start model based upon the '1EX00' snippet of the internal part number. Then we can try to nail this down for you.
Also ...
If it's really a TomTom Start, when you get a chance, please update your profile. I'm seeing only "GO 820" under your avatar, and that's all I had to go on when we started the conversation and I started wandering off into Gen3 discussion.
OK. Found it. Yes, that's one of the old second generation Start series that uses TomTom Home. So you're good to go there. I'd note, however, that this particular unit has only 1GB of memory, so you won't be seeing any new maps for this unit in the future.
First, we need to be 1000% (yes, 100% x 10!) sure that your maps are available because they'll need to be copied back to your device after we try to restore the operating system.
So before we do anything, please perform a backup of your device as instructed here. Do NOT use the TomTom Home backup process.
Next, let's try the simplest approach - reloading the device's firmware:
DO NOT START AT THE BEGINNING OF THESE ^^^ INSTRUCTIONS. YOU DO *NOT* HAVE A MAP WAITING FOR YOU TO DOWNLOAD AT TOMTOM, AND LOSING THEM NOW ASSURES A BRICKED DEVICE. BE ABSOLUTELY SURE THAT YOU SCROLL DOWN TO THE SECTION THAT BEGINS
I don't have a map to download
AND FOLLOW THE INSTRUCTIONS FOUND THERE!
See how that works out for you and please get back to us with your results.
Still get red cross on start up
I followed all the steps exactly twice but a couple of things to note......on tomtom home the option to back up/restore is greyed out...on mange my device it shows how much storage is used but doesn't show what is stored.....I can add/delete maps to/from device but as soon as device is disconnected the red cross appears
That's a strange situation for Home.
When connected to your PC, I assume that you can see all of the contents of your unit using the operating system? I'm beginning to wonder if the file system on your device is corrupt. It sounds like Home can't see the files that are supposed to be there.
Let's do a quick inventory of a couple of things. Connected to your PC, have a direct look at your device with the operating system as though you were inspecting the content of a hard drive. See if you can identify the following files in the root (not any folder) your device:
(root) system
(root) ttsystem
(root) ttgo.bif
(root) settings.dat
Which of those are present?
When you first boot up while connected to your PC, the flashing red X (and the little disk drive down in the lower right corner) are normal, but should cease as soon as the device is fully booted, at which time, you'll just see the same screen without the X or drive.
I could use some clarity on this statement:
" on mange my device it shows how much storage is used but doesn't show what is stored.. "
On Manage, it should show three different tabs at the top: Items on device, Remove items from computer, and Install items from computer. If you click on Items on device, are you saying that nothing appears in the list, but that you see the "Free space" at the bottom left corner? This should list all items installed on your device, in particular "Applications" which is our concern at present.
That the two system files are present is good. IIRC, ALL Nav2 generation devices write a ttgo.bif file, even if it isn't present, when booted up. Why yours has none is a bit of a mystery. Possibly an incomplete boot.
ttgo.bif is an inventory of all of the various features, maps, etc. present on your device, and it is maintained by the device itself. Again, IIRC, TomTom Home makes some use of that file, and if absent, may be why Home has so much grayed out.
Just curious - what version of TomTom Home are you running? 2.21 (specifically, 2.21.19.1592948) is current, and they've been updating it all along.
Here's a screen shot from one of my Nav2 devices:
OK. Home claims, in spite of the ttsystem file we already found on your device, that it has no firmware ("Applications").
When this occurs, Home should always suggest a download of firmware. It appears to be confused.
If you go to "Install items from computer", are there any applications shown?
If not, we may have to attempt such an installation manually, but it will be easier if we can do it through Home directly.
And if not, I need for you to download the firmware by going to this url. Save the file somewhere that you can find it readily on your PC.
Yes. Once you have downloaded the file, open it. A *.cab file is really a *.zip file, so any *.zip utility or your OS should open it when you click on it.
Connect your device, and close Home if it opens or is already open. You will be using your computer's OS to copy files, not Home.
Once the *.cab file is open, copy the entire contents of the file directly to the root of your device (all files and folders).
Be SURE to do a proper logical disconnect of your TomTom (using the USB device icon in the lower right of your screen in the systray).
(This little guy, if you're running Windows 10)
Disconnect your TomTom, and reboot. See whether it cooperates.
Is it just me or is that the wrong file and if it is the right one shouldn't the version be showing
Still getting flashing cross
Ah, you now have an app on your device! That's better than before. It's definitely the right file for your model, as can be seen in the filename for this particular build. It's for START units whose serial numbers begin with XA, XB, XC and XD.
xabcd.CAB-navcore-START.cab
I take it that there is still no ttgo.bif file in the root of your device, indicating that the device really woke up and saw its own content?
If you shut down Home and unplug your device, and plug it in again, does Home start automatically, and does it say it's checking for any potential updates?
Ugh. I had very much hoped that the problem was a simple one of corrupted firmware. Home clearly did not recognize what was on the device before, and although it does now, it's not booting properly.
What are the file sizes of the ttsystem and system files on your device? If they copied correctly, should be about 4.2MB and 1.0MB.
If those are showing up correctly, I'm at a loss as to what we would do next apart from a full format and reload attempt.
Whatever you do, let's first make sure that you can find, in the backup you made earlier, a folder called UK&ROI or Western_Europe or similar that contains your map files. You'll know it because it will contain files such as cline.dat, cname.dat and cnode.dat.
