Hi my Tom Tom go 700 has no sound.
Tried everything within the options and looks like that is not the problem.
Now I have tried using the FM tranmitter built in. That did not work not sure why.
Tried using bluetooth to my LG KU990 which sincted fine but could not use the audio through it.
I took the 700 apart and had a look at the speaker and wiring found a paper clip across the speaker????
could see no damage or loose wire.
Or could it be a software issue. I did buy this second hand so that is a possability.
APP version 8.560
OS 331278
GPS v1.2
Boot 5.5022
Any help would be appreciated
APP version 8.560
OS 331278
GPS v1.2
Boot 5.5022
