I have just purchased a Go 540 Live and would like to hard wire the cradle tyo a 12V source. Can anyone tell me if I can use any old spare mini USB car charger and cut the cigarette lighter plug off it and wire it directly to an ignition fed 12V source. I have a CLK Cab and the main fuse box is directly below where I wish to mount the unit so should be easy.
Just unsure if a straight 12v feed to a USB plug plugged in to the back pof the screen mount will be OK.
Thanks.
Thanks.
