So what type of document text format does 930 gps read ?
Canada
930T
Document reader what text format for 930 gps?
What file extension it reads? Microsoft Word? Txt file? Doc file ? Microsoft Works ? Notepad ?
What directory do you put the document file to be able to appear on your gps Document reader ?
How can you retrieve it out using your gps ?
Zhong
Use NotePad to create a file with a .txt extension and put it in the "text" folder, you will be able to select it and view it on the device from the menu options - Mike
