Problem dowloading Firmware 6.51 for TomTom Go x10
:confused:
When I hook my tt510 to tt home it says no updates.Then while hooked up to the PC I switch tt on and go through the menu to tt plus services press it then press check for updates. A couple of second later it comes back and tells me there is the 6.51 version available on tt home.But no matter what i try I can't get it.
Any ideas anybody?
hmmmm.... Be patient? As I recall you just say 'OK' and it will download the update but there is no progress dialog and it takes a while (well, mine did but I'm on dial)
There might be a message at the bottom of the window that simply says that it is downloading but I'm not too sure about that
m
Hi Guys
Problem sorted it was sitting there already downloaded on My Computer tab of tt home.I had not noticed it.Have now put it on the tt.Sorry about that I have not had it long.
