OK Technical Question - "unuseable voices"
Canada
XL335
US voices work fine on my TT but UK voices say "unuseable voice". Tried switching language
but no go,any ideas? Thanks in Advance!
Jokersmoker
Should work... I've got a French Homer Simpson (!) on my XL LIVE and a couple of Irish voices on my Go940 and they all work fine (without having to change language settings)
Similarly, my Go950 has got US, Australian and Chinese voices on it. They all work too.
Where did you get your voices from? Maybe they are just duff? (or are they TT original ones?)
Jokersmoker
By any chance have you relocated or removed any files from your GPS using a file manager like Explorer?
I know that it's a bit of a stretch, but if you have deleted or relocated some of the reference files for these voices, but kept the control file, I wonder if that could cause the behavior you are seeing.
With best wishes,
- Tom -
