My 910 Window Mount Melted, can i use the car charger
Had it on the window and it melted, i live in Chicago, the inside broke and i have not had it a year yet. Can i still use the Car charger with it??? Cant seem to figure it out.
I looked into buying another and all i see is the FM transmitter mount, is that i have to buy again???
mark
Unfortunately the car charger plugs into the mounting base and not directly into the tt. That is the weak link that caused the problem with the power on and off as well as noise when using the ipod cable. Give support a call.....who knows they may be sympathetic and replace it. The did a replacement for me.
