Flex Circuit Re-attaching In GO-720?
I just installed a new battery in my Go-720, but am having big problems re-attaching the copper colored flex circuit. Any help with technique would be greatly appreciated. Thank you.
Make sure the Brown retaining clip is raised up to around 45 degrees to open the slot, push the cable in to the slot UNDER the brown retainer bar then push down both ends of the retainer at the same time to trap the cable - its a little fiddly but not too difficult, make sure that the copper ends of the cable are all in line with the connector to ensure that its fully seated, if you can see more copper at one end of the strip than the other try again - Mike
