Filter EV Charging Stations
Android App
Is it possible to filter the EV charging stations in the Android TomTom Go app?
I want to filter out the slow (<50 KWh) chargers.
If you select in parameter then profile > electric vehicle you must have the possibility to be on the map or with the option to search for a charging station a station less than 50Kw.
