Bluetooth Remote Control
Is there any bluetooth remote control software for a blackberry 8320 to control TomTom 730? I don't really want to buy a 2nd hardware from TomTom.
I don't think so. Google it and see if you can find it cheaper - but be careful that you get a compatible unit.
I am using the bluetooth with a 920 and a Blackberry 8120. They work pretty good together, BUT - I am not sure if it has anything to do with the remote (as opposed to problems with the TT traffic server), as I have had problems when using both whereby I loose the data link and cannot restore it until I do a clear flash (the pin rest does not help).
Again - could be their server being up and down, but it has happen several times in the last few weeks. It does not happen right away, but after about 1/2 hour.
