1005 Camper not starting
1005 Camper
My 1005 Camper is about 6 years old and has worked perfectly for all that time.
Just yesterday it won't switch on, just keeps cycling the TOMTOM boot screen.
I've done the reset where you wait for the black screen with white writing, press button three times then plug it in but it still wont' work.
Any other suggestions?
Support maybe:
United Kingdom
02079 490 132
Also, try a drum reset on the unit by holding the power button about 20 seconds till you hear the drum sounds.
Tried the drum reset, no good.
I’ll try the telephone number tomorrow but the website says they no longer offer support on the 1005
When you call, do NOT provide a model when prompted in order for a live agent to respond.
Thanks for that.
Reading down the rest of this forum, it looks like this is a common issue.
