Does my unit have the capability to tell the speed limit of a street and warn you if you go over the limit? I can set a limit but its the same for all streets--not good when its set for 45 and I turn into a 25 mph street. Thanks, Walt
The mapping data has imbedded speeds but normally for highways and major roadways only, not for normal streets.
That said, using mapshare corrections, you CAN add a speed limit for a specific street. And you do have a setting for Warn when driving faster than allowed
