XL330s Problem
Southeastern Ma.
330XL
Sends me the wrong way on my street to my house. It thinks my address is about 800ft in the opposite direction. (tells me to turn right instead of left at the intersection near my home.) Is there anyway to fix this?? It seems to me that someone coming to my house using their gps had the same problem. Don't know what kind they had.
The problem is your street has mislocated street numbers on the Tomtom map. As a workaround, you can set your home to "current location" when your are at home.
Check if your house is correct on maps.google.com. If so, then buying a new map will probably fix the problem.
If it's wrong on google, there's not much else you can do. Street numbers are not an immediately fixable error in mapshare. You can still report it, but it'll be a while before Tomtom gets around to fixing it.
I checked Google maps, and yes, it is wrong there. I corrected it there at that time
