I bought an XL IQ Routes Edition last summer and it worked fine until I downloaded the first sw update. From the very first update it would abort during the loading of the patch usually at some random file such as the Portuguese flag file. Eventually after several attempts, the load would complete and I would be good to go.
This continued with every patch / sw update from Tom Tom Home and finally around June 2010 would not update at all,, constantly errored during the update.
So I found instructions here about resetting and formatting the device and then running update. That worked for the first time I tried it. All was good until the August update from Tom Tom Home. I installed it and it seemed to load ok so I headed off on a trip only to find out that the device would reboot every time the rout planning would kick off. It did not matter where I planned the rout to, it would pause just before completing the route and reboot.
So I get back home a few days later and connect to Tom Tom and verify the update was ok. I then format the device again and download the updates again, add my map. USA/ Mex. and give it another try. This time it just reboots at the license "I agree' screen. Every time I press I Agree it goes blank and reboots.
I try resetting, reformatting, reloading, several more times and get the same results.
Oh, I also did a backup of the device at one point when all was working after an update. When I try to restore that BU it just errors on a random file and aborts.
What?s next? Any suggestions?
