Will USA car charger fit European car cigarette lighter
The cig lighters are pretty well standard in NA and Europe. Some years ago, I used my NA 540 XXL in an Italian rental car. No problems.
In a word, yes, even though the ANSI/SAE spec for plugs/sockets here in the U.S. is slightly different.
The U.S. spec for the socket is 20.97+/- 4mm
The Euro spec for the socket is 21.46mm +/- 5mm.
So they make the grounding springs on the plugs stiff enough to hold in a U.S. spec socket without vibrating loose, but not so tight as not to fit well into a Euro socket.
Thanks for the info. Much appreciated
Peter2471
