where is card slot on the one xl-s? * right/left side of street for destination
wherever the rv is
one xl s
I can't find the card slot for my tt one xl-s, and the manual doesn't show one, either.
Is there one?
Is there a way to show whether something is on the right or left side of the street?
My eyes aren't the best, so it's hard to read or see street numbers.
Thanks!
Yes, the manual for the One -XLS does show it. See here:
The slot is letter H.
As to the side of the street, as you move to a destination, the direction arrow will point either left or right, depending upon the direction to turn.
Hi there..
Or you have one of the New XL for Europe which dont have card slots in them.
Have fun
OP: If you cant find a card slot its because it doesnt have one. The memory is internal and none expandable. If I were to guess I'd say you have a 330 XL, or like mentioned some European model or something...
Also it doesnt usually tell you right or left when you get too your destination. The screen will display it when you get really close but its not pronounced....
Reido
