I'm trying to find out what might be stopping xulrunner.exe that comes in TomTom HOME V2 from running on XP Pro.
It will run on XP Home without any problem.
I've tried running it alone (C:\Program Files\TomTomHOME\xulrunner\xulrunner.exe), I tried it in "Safe Mode" I also downloaded a fresh version (not from TomTom) and tried that!
I've stopped everything (practically) under processes (Task manager), I've stopped almost everything in services; (tried xulrunner) then re-started them after e.t.c.
Just can't figure out what is preventing it from running?
If I stare at the xulrunner error dialog box long enough, TomTom HOME will start behind it, and if I drag the error box aside (not closing it) the software seems to function fine?
If I make any choice in the error box (Debug, send a report to MicroSquash, or Close), it closes and closes TomTom HOME as well?
What could be causing this error ?
