Could you suggest a modulator?
My old favorite is no longer available and already has a home in the other car, but in a day or two after it arrives, I'll report back my most recent purchase -- it's the same as the one you'll find here:
http://www.amazon.com/gp/product/B000AR8VEK
If anything will work, that should. Frankly, as only 1/10 watt maximum power is allowed on these things, it's a miracle that they work as well as they do, especially in town. The one I already own does do better than the TT's FM modulator. It allows for 3 preset frequencies that can be accessed quickly (vs. the 2 for the TT itself).
That probably isn't the best price you can find on this unit, but be sure it's
this one you get (the RadioPlay
300) and not something similar. Some other brands and another Monster unit are restricted to being tuned to a limited set of frequencies.
This one covers the entire FM band. You do NOT want the cheaper one (same Monster brand name) that allows use of only 88.1, 88.3, 88.5, 88.7, 88.9, 89.1, 89.3, 89.5MHz. You want the "full spectrum" version that allows tuning across the band! More chances to find some dead space in a busy city.
As the 720's "line out" audio is fairly "hot", I don't expect any problems with volume at the radio end, but we'll see.
If you're impatient, they've got this unit for more $ at most Radio Shacks, too. Pricegrabber shows it can be had for $32.99 and free shipping.
