Warning when near POI (ie, POI alert)
I read this write-up, and it makes sense.
https://www.tomtomforums.com/showthread.php?t=1805
however, in my ONE LE, after selecting a default (ie, from the factory, not custom) POI to warn, the next screen allows us to choose a alert (ring, bell, buzz) that will play when you are a certain distance from the POI. I'm assuming custom POIs (redlight cameras, speed traps) are the same way. So if TomTom allows usto choose one of their alerts, dose that mean there's no need for *.ogg or *.mp3 files?
Yup, you're correct.
I need to update that tutorial as NavCore 7 handles the alerts differently. If you want to have custom alerts, then you can place all the *.ogg files in the folder called Sounds.
You can name the *.ogg file to whatever you want so when you come to the screen showing all the factory alerts, you can scroll down and it will also show the custom ones too.
Adjust speed warning? 7
GO 5100 warnings 14
Overspeed Warning 5
Speed camera warning sound 0
One wish. Improved visual warnings (speed cams) 1
Go live traffic warning triangle 9
Radar warnings 2
POI Warnings 6
airic
