Van speed limits
Hi
Normally, if your van weighs less than 3.5 tons, the speed limits are the same as for cars.
Afterwards, there may be speed errors, connect to mapshare to have them corrected.
Hi folks,
Im looking at buying myself a TomTom satnav and was wondering if it displayed the correct speed limits for Vans in the UK when in van mode.
For example my old different brand satnav used to show a limit of 70mph on a dual carriageway when set as a van when the UK legal limit is actually 60mph.
That's where the ability to define your vehicle type can come in handy on devices like these:
Might be worth reading up to see if this will help you out.
Annoyed tomtom user
