canderson
Moderator
- Joined
- Dec 28, 2007
- Messages
- 13,359
- Location
- Colorado, USA
- TomTom Model(s)
There are (presently) two versions of the online TomTom planner available fpr your use, each with a somewhat different look.
The older version can be found at https://mydrive.tomtom.com
The newer version can be found at https://plan.tomtom.com
Here, find a handful of videos on using the MyDrive route planner. It provides a means to create routes, and for some models, move routes and POI files to and between your devices:
How to import POIs, GPX files and Favorites in MyDrive (Nav4 WiFi Units do not support custom POIs)
Creating your own routes with MyDrive
Sharing your routes with friends on TomTom Road Trips
