I'm a 'virgin' TomTom owner so didn't really know what to expect. I was a bit concerned when reading the user manual for my new GO 6100 and seeing the number of warnings about only using the supplied USB lead with the device as others might not work. I never take anything at face value and I couldn't believe there was anything special about the supplied cable ... and besides I wanted to leave it connected in the car, I didn't want to have to keep removing it every time I needed to connect it to my workstation indoors.
My Kindle reader's lead has the same USB Micro B connector on the end so I gave it a try and it works perfectly without any apparent compromise to transfer speeds.
A word of caution though before you go trying any leads you might have. Make absolutely sure it has the identical connector as the TT supplied one. There are different shapes of small USB connectors so don't go trying to jam any old lead in without checking carefully or you could damage the TomTom's socket.
