US Map help required
West Yorkshire, UK
Navigator 6 (soon to be version 7!)
I currently run Navigator 6 on HTC Touch HD (Blackstone) but currently upgrading to Navigator 7.
My problem is that I travel to the US in April and have found that version 7 doesn't have US maps available.
What are my options (if any)? - For example can I use US maps from previous versions.
Thanks in advance.
Mark P
West Yorkshire, UK
Nav 7 needs compatible maps for it to work, it won't load the older maps you had for version 6, consider switching to Sygic see Here which has a user interface very similar to the TomTom on a PDA and has up to date maps for the countries you want - Mike
You can buy an One 125 (US version of the UK One-30) for less than the price of a map. You may want to buy it as a "disposable" device for your trip.
