- Joined
- Mar 16, 2008
- Messages
- 19
- TomTom Model(s)
- 700
I'm trying to update the speed limits on some local streets, but the editing function within Mapshare leaves a lot to be desired. For example, Mapshare highlights the entire over 60 mile stretch of a road, which assumes that the speed limit is the same for the entire length. In fact, it varies from 25 to 55, depending on whether it is going through a town or not. This requires me to de-select over 60 miles of road, in half-mile segments (and since it is 2 way, there are 2 parallel segments.). And even using a stylus, TomTom sometimes selects other areas when I'm trying to de-select. It is too sensitive.
There needs to be a way to specify the start and end point of a segment, so that I can set the appropriate speed limit.
