Hi all
I just updated my maps to the 8.25 maps and now when I search for a POI it immediately says no poi found. I have done a pin reset and the same things happens. Am I doing something wrong?
do you know why the search poi no longer brings anything up? I used to go there and get whatever I needed. I tested it again by loading my 7.10 maps on again and using the search poi and it worked.
i've had the same exact question and i thought i actually screwed it up myself.
it's soooooo annoying to having to select a POI cat before finding one. for example... i was looking for a dick's sporting good... who the hell knows what cat this is in, i've tried sports, shopping, and nothing.
i sure hope someone fixes this. i'm having so much problems since updating to this latest map. i really regret doing so.
I noticed that when I updated the maps none of the Mc Donald's POI's show anymore. They are turned on to be shown and they are on the device. Haven't noticed with any other POI group and I did report it to TT.
