I prepare complex TomTom route files in gpx format for classic car driving events - these may use 20-30 waypoints to create the required route. Over last weekend a problem appeared when the Severn Bridge was closed & unfortunately this was in the middle of our route. Those using the TomTom Go app was unable to open the route so had to follow another team who was using a paper map or a Garmin satnav (i know heresy on this forum).
My question is is it possible to modify the track on your phone so that the closed road can be avoided? Its easy enough on a PC where the plan.tomtom.com allows you to move GPX waypoints, but is there a way to do this on a phone?
Howard
Howard
