The car mount is a great accessory; I actually use it a great deal more now that winter is starting to creep in. It?s great, that is, when the setup works.
The mount receives power; my TTR2 comes to life when I turn on the ignition and shuts down when I turn the ignition off.
When the TTR2 is in the car kit and the ignition is turned on the TTR2 comes to life and shows ?Connected to hands-free car kit?. But I only get audio about 5% of the time. That is, 5% percent of the time that it get?s turned on. What gives?
I try touching the lower left hand of the screen when you adjust the audio and the voice speaks, but you hear nothing and it shows ?Connecting to headset? every time you press it.
Often times, the only way to get it to work is to power it off and/or remove the TTR2 from the car kit and reseat it back in. But even that did not work for me today no matter how many times I tried.
Is it the TTR2, the car kit or something else I am doing wrong?
