Hello all,
How can you view the TT1's current wireless data connection settings and then change them if necessary? All I see in my prefs is Disable or Enable Wireless Data. Thanks.
On my XL-S the settings adjustments were accessible when I went to the TT
Plus menu and tried to use the weather or traffic, it told me I had to set up the
data connection and gave me an option to do it auto or manually. I think that's
the only way to access/change/view them. In there I found the phone models,
carrier, BT pairing info etc.
