TT One 130 - Tripmaster help
Just purchased a refurb TT One 130.. Has App 8.041
Have loaded Tripmaster but it won't start.. I have the Icon but when I touch it, it returns to the map screen.
Have have looked on the forum for some time but cant find a solution..
Please advise..
Gordon
Per the tripmaster web site, version 2.4 and 2.5 do not work on the One V3, which is essentially the same unit as a One 130.
You might have luck if you try version 2.1 here.
