Hello. I posted previously about locating a direct power cradle. I appreciate to replies, but it's not worth the $60+ to do it, for me at least. So instead, I am trying to located at least the direct power wire so I don't have the cable strung across the dash area plugged into the cigarette lighter. I did locate a wire, but it seems to be a bare end and I'm not sure if it is fused or not; or if it even requires one. Is this the right one?
Do I just go to radio shack and get one of the jumpers where it plugs in behind one of the fuses (clips to the fuse, then you plug the fuse in)?
Thank you.
Thank you.
