TT 335 S Problem
Status
Not open for further replies.
I recently got this TT 335 S, worked fine right away, then came the update... After several attempts to update (they all failed) I got things to stick, restarted the device the correct way and the screen froze.
I read up on how to fix it, it says to delete the application and re-install so I did that...about 27 times all with the same outcome...nothing.
Through all the deleating and re-installing the map that came with the device was lost, I had purchased a updated map but its too big for the device (would have been nice to know before I paid for it) So now I have no maps on the device because there is not enough space.
At this point making a backup is pointless because there is nothing to back up...
Is there a safe way to wipe everything out and just restart??? If I reformat via my comp, when I start everything back up will it act as if its a new device?
Need some help in a major way....
Replied in your other thread here
Not a good idea to post in more than one forum as it fragments responses. Locking this thread.
Status
Knot
