- Joined
- Mar 18, 2023
- Messages
- 9
- Country
- TomTom Model(s)
- 740 live smart 50
Hi all,
My start 50 has begun playing up, after not being used for 18 months, though left connected to keep battery topped up.
The touchscreen has stopped working, and after popping the unit apart to investigate I found the sticky tape on the ribbon lead to the screen has begun to peel off,and when I pressed it between two fingers the screen worked properly.
As a temporary fix I've stuck a small strip of electrical tape on it and it appears to have worked.
What could be the actual issue, as I don't believe a bit of sticky tape would cause the screen to stop working? ( the screen is on, but no touch activation)
